Old 03-31-2025, 10:08 AM
kf4rca kf4rca is offline
They continued as CBS Laboratories. They made the Audimax and Volumax which were the standard for radio stations for many years.
Also they made the Vidifont, which was an electronic typewriter for TV stations. It loaded fonts from 8 inch floppies. (Remember those?) It was a wired logic design. It was superseded by the Chyron which could do graphics. It had a microprocessor. It also used 8 inch floppies.
Old 03-31-2025, 12:03 PM
Does this match your set?
Riders vol 13, chassis
First time I have ever seen a focus control on an electrostatic focus set. Usually, it's a jumper with 2 or 3 options.
I've been curious if it gives a smooth focus change. If so, why didn't more sets use a variable control?
Old 03-31-2025, 12:08 PM
Lots to check for low HV.
6BQ6 HOT
1AX2 HV rectifier
6W4 damper
1M resistor in series with HV lead
0.51 ohm current limiting HV rectifier resistor
500pF, 20kV HV filter cap
Horizontal grid driver amplitude
Old 03-31-2025, 12:09 PM
we’ll the tube line up looks the same but it shows the magnetic focus tube which would be different if it’s got the 21yp4 then it’s probably the right one.
Old 03-31-2025, 12:25 PM
All tubes are 100% anode wire resistor good limiting resistor measures 1.7ohms and the 1x2 heater does light up,, correction I measured with the tube in so I probably measured the heater filament but it does light ok. Limiting resistor is 0.7ohms
Old 03-31-2025, 12:56 PM
The schematic shows both. The dotted line is the for the electrostatic focus CRT.
Anode wire resistor should be 1M, not 1.7 ohms.
Filament limit resistor should be 0.51 ohms. 0.7 is close but it will run the rectifier tube a little lean and could possibly reduce the HV output.
Old 03-31-2025, 01:04 PM
The anode resistor is .93 just shy of 1 meg yup I see it I missed that in the schematic for both. The 60 ohm resistor for the b+ I have a 68 ohm in there that measures 69 ohms could I put a 50 ohm in there instead ?
Old 03-31-2025, 01:16 PM
Some 60s Zeniths had it. It didn't have a very sharp peak IIRC so it was probably seen as about as good to jumper (only cheaper) by most makers
Old 04-01-2025, 11:46 AM
Unless I had the correct sams I can’t go on some voltages, I have b+ 360v focus 351v and boost 575v seems high since the sams I have says 490v boost and b+ 305v and focus should be 300+ I’m not sure where the hv should be it’s at 13 kv , bright down close to 14kv
Old 04-02-2025, 06:32 AM
What is the difference between the old wax yellow caps and the black bumble bee caps. What can go in place of the bumblebee cap.
Old 04-02-2025, 07:02 AM
I'd use orange drops. If you can find them. Don't be vague. ask for Sprague.
If your voltages are within 15% they are probably OK.
Old 04-02-2025, 08:11 AM
The only difference between a bumblebee (paper dielectric like most plastic body tubular caps of the era) and a wax paper cap (also paper dielectric) is the plastic housing designed to keep moisture out. Both suck equally bad. Replace with any decent film caps. Orange drops are good assuming they aren't too old (I've seen nos 60s specimens that were going bad), new production I favor the maroon ceramic coated Panasonic film caps mouser and digikey sell. Good quality and reasonable price.
The yellow caps some of the radio vendors sell are good to despite some disliking their aesthetic. Just don't melt the body with your soldering iron. They are good for restuffing which is my main use for them.
Old 04-02-2025, 08:41 AM
So would that mean a ceramic disc is out of the question ?
Old 04-02-2025, 08:58 AM
Not recommended, as they tend to drift, unless they are a very stable NPO type.
https://www.allaboutcircuits.com/tec...pacitor-types/
Old 04-02-2025, 11:48 AM
Generally if an original cap in a TV is paper it's a bad idea to replace it with ceramic...you can get away with it in audio circuits and input power line noise bypass caps, but I wouldn't use them elsewhere unless the original cap the manufacturer used was ceramic.
Replace paper caps in TVs with film caps if a sufficiently close modern film caps value exists.
You can get some spooky issues and strange drift from ceramics doing a film caps job.
