Old 05-23-2025, 11:34 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
TS18A schematic
Looking for a copy or original TS18A schematic. I have the Sams but it’s not really close to being right. Set is a 9T1. Thanks
Old 05-24-2025, 10:41 AM
Here's a schematic from the Wallace Telaide.
https://flic.kr/p/2r6HipB
Old 05-24-2025, 05:13 PM
mstaton's Avatar
"Book em Dano!"
Thanks Bob. The only issue I see is that my horizontal transformer had 6 wires. I only seem to find ones with 4. Mine is attached to the outside of the chassis
Old 05-24-2025, 06:23 PM
I have several TS-18A chassis and all have it mounted on the inside with four wires. Could yours be a replacement?
Old 05-24-2025, 06:26 PM
Scratch that comment. I do have one like you described. https://flic.kr/p/bDAkFZ
Old 05-24-2025, 06:49 PM
mstaton's Avatar
"Book em Dano!"
That’s the one
Old 05-25-2025, 10:39 PM
mstaton's Avatar
"Book em Dano!"
If you have a schematic, I’d be happy to pay you for it.
Old 05-26-2025, 11:00 AM
Nope, not that I can find. I went through Wallace and Riders. Neither has a TS-18A "late" schematic.
Old 05-26-2025, 06:04 PM
mstaton's Avatar
"Book em Dano!"
Thanks for trying
Old 06-08-2025, 04:21 PM
mstaton's Avatar
"Book em Dano!"
Will low high voltage (3.5k) affect sync. I tried different (used 1B3’s) some kinda work, some don’t. Still has the original Motorola 1B3. BTW, I ordered some new ones in case
Old 06-08-2025, 04:34 PM
It might affect vertical sync since the plate voltage for the 6SL7 vertical output tube is derived from the HV supply.
You probably know you need to slide the feedback coil around the 1B3 to find the sweet spot that gives the best HV.
Old 06-08-2025, 04:38 PM
mstaton's Avatar
"Book em Dano!"
I tried that, no luck
Old 06-09-2025, 04:14 PM
Low hv, change those domino looking micas and there’s one on the hv coil
Old 06-09-2025, 06:15 PM
mstaton's Avatar
"Book em Dano!"
Okay
Old 06-21-2025, 09:22 PM
mstaton's Avatar
"Book em Dano!"
Sad news, the CRT filament went open. I’m pulling all the caps and moving on. Too bad because the cabinet is very good.
