Old Today, 03:23 PM
I would if I could. Seems like they installed the tuner first then mounted a bunch of stuff around it including the CRT support structure. The result is two screws are nearly impossible to access.
Old Today, 04:41 PM
How did you get that chassis so clean looking new ?
Old Today, 06:48 PM
I didn't do much. I just wiped down the topside with CLR. The underside of the chassis has a solid metal cover that kept everything clean.
