Old 11-30-2008, 10:25 AM
That thing is gorgeous! Excellent save! I've never seen a white one, only the black with gold trim.
Old 11-30-2008, 11:16 AM
Adam's Avatar
Adam Adam is offline
The cabinet was made by Zenith, they made two different chinese cabinets for their early color televisions that I know of, one was this white one with the designs on the front, the other a black one with just the gold striping on the edges.
Old 11-30-2008, 12:27 PM
Tony V's Avatar
Tony V Tony V is offline
Adam,
I'm glad you got it. At least we know its in good hands now. Cant wait to see a picture on it!
-Tony
Old 12-04-2008, 10:20 PM
Thyratron Thyratron is offline
Good job! You didn't happen to get any pictures of that living room, did you? (Well I guess that the owners might not have approved, but it sounds pretty incredible).
Old 12-05-2008, 10:05 PM
Adam's Avatar
I thought about it but I didn't have a camera on me.
Old 04-16-2009, 05:20 PM
Adam's Avatar
I pulled the chassis. The guy I got it from said that he was using it as a daily watcher for the past few years, until the breaker started going off when the tv warmed up, and this is when he decided to sell it. So the first thing I did was to check the diodes, they were good. Then the 160mfd electrolytics, not so good. I think I'm going to just replace all the electrolytics. I swapped the bumblebee caps out with orange drops this afternoon.(There were actually quite a few in this set - I wasn't expecting them in this late model of a set) I'll replace the electrolytics in a few days.
Old 04-16-2009, 08:00 PM
This is a real 100% Zenith produced at the factory. Zenith contracted with Drexel furniture for the cabinet, but it was all put together at the Chicago plant.
julian
Old 04-16-2009, 11:56 PM
Heat sinks on the power transformer? Must get pretty hot in normal operation, no margin if there's a leaky power supply cap...
Old 04-17-2009, 06:27 AM
Back then we were not worried about leaky caps. Also Zenith was not replacing transformers either! It was a well designed chassis albeit obsolete for the day. Zenith would not spend the money to "modernize" their assembly line which made an expensively built chassis.
julian
Old 04-17-2009, 08:06 AM
Those transformers do get pretty hot, especially after watching the set all day like I do sometimes.
Old 04-17-2009, 10:27 AM
kx250rider's Avatar
REAL TVs have TUBES!
Oh yes... You burn your hand if you try to carry the chassis by the transformer after the set's been running. Same with CTC-16s et al. Those transformers hold in heat like a Thermos bottle!
Charles
Old 04-17-2009, 10:31 AM
Clean chassis. Did you work on it, or was it that way ?
Old 04-17-2009, 09:10 PM
I've heard that in the prewar era Zenith has trouble with transformers being underrated; I wonder if that was still on their mind?
Old 04-18-2009, 11:05 AM
kx250rider's Avatar
Not sure, but I do know they had a bad reputation for failed field coils in the prewar radios, since the field coil was also the input choke for the power supply. Any load, such as a leaky filter, would overheat and open the field coil. Shoulda put a fuse!
Charles
Old 04-20-2009, 03:30 PM
Adam's Avatar
That was the way the chassis was when I got it.
I recapped the electrolytics and checked all the tubes. All the tubes were good, and except for the damper they were all original. I would guess this was a very low hour set. The guy I got it from said he had it shipped out to CA from Kansas a few years ago. It probably saw more use in those few years he used it as a daily watcher than it did when it was new.
pics of the chassis after I cleaned it up and recapped: http://www.audiokarma.org/gallery/sh...&size=big&cat=
