Nice Philco on ebay
It appears to be in nice condition.
There seem to be quite a few sets showing up in Michigan recently. Maybe it's our poor economy. John |
Wow, that is a beauty. Wish I was close as well.
Reminds me of the HOWDY DOODY philco that was bought by a member here.
![]() Steve |
My grandmother had one of these in 1951:
I like the curves of the cabinet .
The seller doesn't think the channel knobs are original , they look like it to me ? |
Yes, the knobs are original. It's the typical soft-plastic knobs and the painted aluminum (?) channel selector.
To Mr. Tube TV...these are actually fairly common. Depending on your location, you should see one of these at a local meet, or on ebay, closer to you, if you keep looking. Harry |
I have the square cabinet version. Although a difficult restoration because of all the bumble bee's, i was rewarded with a nice picture afterwards.
-Tony |
I've been holding off on restoring my 50T-1401 for that reason. Glad you got your working.
Has anyone had the tuner in one of these draw excessive current after warmup?
I have a 10", and a 12", and both have this problem. Picture fades to blank raster after about 7 to 10 minutes. Kevin
stromberg6 |
A crude test would be to measure the AGC voltage when the set is first turned on and operating normally, and then watch to see if the AGC voltage changes as the signal gets lost. Then you could impose an external voltage on the AGC line the same as the good AGC line voltage to see if you get reception back.
A pity that the seller appears to be well on his way to parting out this
set. The question from a potential buyer 'just wanting the cabinet to display in a nursing home' is appalling. Let's hope this finds a good home. Last edited by electroking; 07-03-2009 at 05:01 PM. Reason: corrected spelling (again...) |
Thanks for the suggestion wa2ise. I'll do just that.
Kevin
stromberg6 |
Appalling in another way too - I can see some poor soul trying to turn the knobs, which are glued to the cabinet...
Did anyone here win it?
John |
