#61
nice series of pics, you can see the "fingers" working across as the pva releases. I could prob do the same to mine now, I just dont have a decent way to hold the CRT in place (for the sun bake).
#62
Hey Dave, i, as you can see, just used a standard garbage can with some 10 lb weights in the bottom so it wouldnt be too top heavy and let it do its thing. In the beginning i wasnt so patient though, i kept looking every day to see if the water was working and eventually just forgot about it. The tube tests good, however, and now i just have to install it and see how it goes. good luck buddy
#63
roger that. FYI I have made my stockholm my daily watcher, The old CRT is working well. I never retested it after the inital check out where it tested weak.
The one I am soaking test very good so I am looking forward to getting it done and will install it in the stockholm (will then do the process on its crt which is also needing a de-cat. Are you planning on reintstalling the lens? I have a CTC7 that will prob get the next CRT I de-cat, that way I dont even have to worry about reattaching it. |
#64
cat removal
actually the last picture in that series of photos i posted is the tube with the lens re-installed, i used the strips of foam tape and taped up the sides with some clear packing tape. Im glad that youre getting life out of that Stockholm. I just moved into a bigger house and mine is the daily watcher and the center of the living room, its just so damn cool looking...Bruce
#65
oh yes I bet folks say "wow nice color I did not know they looked that good" when they see yours, I get that a lot. I have another CTC-16 that needs a new cabinet that I hope to put in a bedroom, its vertical (speaker on the bottom) so up a little higher for better viewing. I am also digging on the phono and stereo, when there is nothing on tv to watch.
#66
Did you silicone that one or just tape it? Im not a fan of just taping it, the dust is going to find a way in there. The GE silicone 1 works very well and adds alot of strength to the glass. You can always cut it off if you need to.
#67
silicone
I will give it a try, thanks. Having only done this a couple of times, i figured if the side was taped it would be good. The silicone sounds like a good idea though.
#68
Tape kinda drys out and flakes off especially in a hot dry environment like a tube tv. The way hawkeye did it was used a solid ring of the double sided tape with no gaps, his tape is more like weather stripping. I went with the bead of silicone because I never want to remove the crt for cleaning.
Its all experimenting, trial and error and learning. There really is no wrong way unless you break the glass. |
#69
Done...
I got tired of waiting so I put in out in the sun with a few chop sticks around the perimeter, about 45min total and it popped off. I have a few scratches on the lens (not the CRT) that I have to deal with, I dont know how they got there but they are there and right in the field of view. anyone have suggestion on scratch removal? I was going to head down to the auto parts place to see what products they have, or maybe just take it to a auto glass shop and see what they can do. |
#70
another one done, 20min tops.
This was one of the green cats found on zenith tubes. I put it in the sun for about 15min, then used some SS saftey wire (.007 IIRC) and looped it around the perimeter just under the lens. I tied it off with enough space to get a thick piece of card board under it to protect my hands. then just started pulling. It cut thru the gelitin consistancy plastic goo. Once I pulled it completly thru the lenes lifted off. Most of the goo stuck to the lens, very nasty stuff. I next put the lens in my wading pool (in the shade so the water is cool), and the goo quickly set up. allowing a pretty clean pull off (was like rubber coming off after cooling). the lens will still need some cleaning but its 95% goo free now. Bottom line is the green is easy but a bit messy, the white is a bit more of an effort but pretty much mess free. |
#71
Another successful cat removal. I have a 21FJP22 that had a pretty severe cataract.
![]() I decided to try the "water" method and plopped it face down into an overturned garbage can lid. It sat there for about 3 weeks. Today I wanted to see how much progress I made and pulled the tube out of the water and turned it over and placed it into a plastic recycling can. It's a perfect fit and a stable way to hold it. I then took several wooden paint stir sticks and began to push them in between the tube face and the safety glass and sat it out in the sunlight for a while. ![]() I started to notice the safety glass showing signs of release from the bonding agent, and over the coarse of the next hour I slowly pushed the sticks in further and further. After about an hour I could see I was getting close. All of a sudden the sticks all fell to the ground and I picked up the safety glass off of the face of the tube. ![]() ![]() I then carefully peeled the bonding agent off of the face and that was it. Done. Here's the bonding material after removal from the face of the tube. ![]() It took just three weeks to accomplish. Patience does pay off in the end. Bob |
#72
yep. same thing here. I watched the bonded area start going fast until it was about the size of a dime, then a pretty loud "pop" and it was done.
Nice job you yours. |
#73
cat emoval
dont want to be premature in case someone else has a better way,but, i think we got the way to do this......
#74
the green goo remnants were cleaned off with some gasoline, looks good, so I will use this lens for the good roundie since the one I popped off had a bad scratch in it. The plan is to seal up the tube with the lens (maybe tomorrow) and then to install in the stockholm. the stockholm tube will be de-cat and will be a spare, or will go into the CTC-7 table top (metal cap faux wood finish) if that chassis is fixable.
#75
Nice work guys and thanks for the pictures. Hopefully I'll be giving this a go here myself soon. We're having a real hard time transitioning into spring, seems it's been snowing most every week in April.
![]() I wonder how much the water soak helps, or if it's mostly the sun doing the softening? |
