Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > The Amateur Radio Spot
Old 07-15-2012, 08:25 PM
W3XWT W3XWT is offline
3 Phase 480VAC is QRP
The mobile mount is a 2006 Hummer H3. The trick to successfully grounding it was found when I crawled under it. There is a 1/4" wide aluminum braid coming off the powered sub-woofer of the "Monsoon" sound system. grounding the rig and the base of the antenna mount solved a multitude of evils.
Reception Reports for Channel 37 TVDX Can Not Only Get You a QSL Card, but a One-Way Trip to the Planet Davanna is a Real Possibility...
