Old 09-12-2013, 07:21 AM
6GH8cowboy 6GH8cowboy is offline
Remote of CTC-10
Been working on a set for TVCOLLECTOR and the remote was badly damaged by leaked battery at one time (not original remote to the set).
This is the one with the lucite buttons. The copper foil is about gone in many places. It has been carefully cleaned. I have replaced the traces with wire, replaced both caps, and transistor. Continuity checks indicate good path end to end from components to contacts on all functions. Only one function works only some of the time, the rest don't. The scope shows only a burst with no sustained oscillation.
I suspect either the PCB material itself is contaminated in some way and no longer a good insulator or the coil is bad. In this hobby remotes seems to be a nitch within a nitch. If anyone has a good idea or insight it would sure help.
This device has a great look and feel; like how the car doors closed in the 50s. This is going to be a awesome final touch if I can get it working and stable.
Old 09-12-2013, 04:07 PM
tvcollector's Avatar
I spent close to $100 on this device so any input to get this working would be greatly appreciated ..
Old 09-12-2013, 07:07 PM
I can only suggest the usual suspects, Caps and Resistors.
Old 09-12-2013, 07:41 PM
Yeah, the resistors check out and both caps have been replaced and the transistor. 4.5v Power.
I have a bad gut feeling about the coil. The windings come out to the terminals and can be seen. All the wires are redish colored exept one is greenish/ blue. If that winding was that color for sure there should be two greenish wires (to one of the other terminals), not just one.
Old 09-17-2013, 02:24 AM
Tim's Avatar
Tim Tim is offline
I happen to have a remote apart. The 4 wires are enameled copper color. Two coming out the back and two out the front. You should be able to measure continuity through the coil.
Tim
Old 09-17-2013, 06:12 AM
Yep, I have contimuity from end to end (coil wise). When I have a scope near it I see a very quick burst of signal but it won't sustain.
The color of the conductors are copperish red with the exeption of the one wire near the front (greenish colored). If the wire was indeed green there should be another green wire on a terminal. Being this unit had a bad battery leak at one time I'm suspecting the wire sleve wicked up some juice into the coil. The circuit is fairly simple and all small parts have been replaced exept the coil. All visible trace of corrosion and gunk has been removed. The bad traces have been replaced with wire and an ohms check shows the right path at the right selection.
I can only deduce the coil is damaged or the pcb material has been changed from years of "acid storage".
Old 09-22-2013, 09:40 PM
A second CTC-10 remote transmitter.
Working on a second remote unit. I have good signal after replacing the transistor. Three of the signals seem to have two states. Dead carier (so to speak) and a modulated/ switched 50% duty cycle signal.
Is there a write up for this. I think I have it figured out at the recieve end, but documentation would sure help. I would rether not adjust anything until I have more self notes or real info. This is way different than anything I've seen before! But still very cool if it operates like I think it does.
Old 09-23-2013, 06:10 AM
Old 09-26-2013, 09:03 AM
Any input would be much appreciated..
Thanks..
Old 09-27-2013, 02:26 PM
Sorry I have no input for this, just wanted to say I never saw the inside of this type and will eagerly wait to see the outcome.
Old 09-27-2013, 07:23 PM
We were able to get the remote going.. Pictures of the set is to come..
Old 09-27-2013, 08:11 PM
Super! Do you have some idea of what the waveforms are?
