Old 07-18-2015, 08:14 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
Ok that fixed the picture issue I now have sound but no picture signal from my pattern generator. what is going on now?
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 07-18-2015, 09:19 PM
you prob bumped a tube, wiggle tubes, even if filaments are lighting and esp if not.
Old 07-18-2015, 09:39 PM
SwizzyMan's Avatar
Hmmm didn't do anything...
Old 07-18-2015, 11:16 PM
Check your B+ lines. If one that drives the video is out/low that could be the problem.
Old 07-19-2015, 06:33 AM
show a video of the problem. include changing channels.
Old 07-19-2015, 07:41 AM
SwizzyMan's Avatar
Here is a video of what is happening https://youtu.be/V7HpOP1hUtk
Old 07-19-2015, 12:08 PM
SwizzyMan's Avatar
Was able to somewhat get a signal https://www.youtube.com/watch?v=hja20nVWWiw
Old 07-19-2015, 03:57 PM
60s Throwback
Did you try switching to channel three?
Old 07-19-2015, 04:00 PM
tvcollector's Avatar
Did you restuff all cans and then turn it on, or did you restuff one can at a time and turn the set on? It's better to do one can at a time so if a problem happens you know which one it is, and easier to find the mistake...
I would try running a coax directly from a cable box or DTV converter out, on to channel 3 and see what you get...
Old 07-19-2015, 04:02 PM
SwizzyMan's Avatar
Turned to all channels
Old 07-19-2015, 04:03 PM
SwizzyMan's Avatar
Ran it without the doubler for a little bit but then I reconnected all the leads I have tried all channels the signal is intermittent and the picture signal is horrendous.
Old 07-19-2015, 05:50 PM
ran it without the doubler? what does that mean.
quit using the generator give it a real signal from a DVD or converter box.
Old 07-19-2015, 05:55 PM
SwizzyMan's Avatar
without the doubler as in I did not connect the negative end of the cap to anything.
Old 07-19-2015, 05:59 PM
SwizzyMan's Avatar
And no luck with a signal from my bt modulator with the input plugged directly into the RF out. Sound is fine just a very bad video signal.
Old 07-19-2015, 06:30 PM
I would assume that would be why there is problems, each cap in those cans you restuffed needs to have the negative leads connected to ground, as in metal of chassis, unless those cans are isolated... What I would do is connect all neg leads from each cap in each can together soldered, and run a wire soldered to them to a spot on the chassis that already has a cut out where ground leads are already solder too...
