#181
Admiral C322C2 Regent (Restoring) RCA CTC-7 Pensbury (Restored) RCA CTC-5 Westcott (Restored) CRA CTC--4 Director 21 (Restoring) |
#182
I have asked for pictures of the work done, I can't help you as I can't follow your written response. You need to get a pic of the work done on the cans.
also if you are getting a rastor the work is prob ok. That being the case you need to confirm you have the tuner hooked up right (leads connected etc...) you should try an alternate source of RF. from the looks of it I would guess an incorrectly hooked up ant lead or maybe an RF tube. did you wiggle that one in the tuner? |
#183
#184
Here are the pictures scroll down to the bottom to see them I took 6 of them
http://imgur.com/a/oTaRJ
#185
at what point did you lose the video signal?
its hard to tell whats going on with the caps even with the pics. make sure you ant connections are good from the ant term block back to the tuner. Did you wiggle the RF tube in the tuner? |
#186
lost the signal after a few seconds of having it on for the first time. Wiggled the tubes helped a bit not much though
#187
Ok wiggled the connectors and now I have a coherent picture but the horizontal is bending and the vertical isnt very stable
#188
Seems that just tv shows mainly mess with the horiz and vert hold but the crosshatch and the alignment patterns are somewhat better but still iffy with the holds. The color bar patterns are a lot more stable. Could this be bad caps or a coil adjustment?
#189
Wiggling a tube is only a temporary cure for a situation where a tube has dirty/corroded pins, or its socket has dirty/corroded connectors, or both. Have you every tried cleaning them? See http://antiqueradio.org/FirstStepsInRestoration.htm . If wiggling a connector makes things better and worse, that connection needs to be cleaned or resoldered, whichever is appropriate.
Phil Nelson |
#190
DO NOT ADJ ANY COILS if you do all bets are off. |
#191
also for now stop using the BT, use the RF out from a reg DVD or converter box.
#192
So for sure that is what is causing the bad horiz and vertical hold? I think some of that power transformer wax has dripped onto some tube sockets the underside of the socket where the solder joints are. Could that be causing problems?
#193
more likely the RF source which is why I keep asking you to change it.
#194
Alright sorry just wanted to make sure there was not going to be any further problems with that wax. I'll take it out today and do what I can.
#195
as previously stated, you need to make sure tube sockets are clean esp since it seems they maybe part of the intermittent video signal.
One issue at a time, get that worked out 1st then next will be the horz/vert lock issues. My guess is you have an AGC or sync separator issue (or a signal issue from the RF source), there are many causes for this, but again FIRST get the intermittent issue worked out. you should not have to worry about just touching a wire or a tube and have that cause a problem. on and DONT squirt cleaning solution all over the sockets, esp the tuner. Rather pull the tube out spray the pins, then insert the tube several times. Most times that is all that is needed to clean the socket. Look at the pins of the tube if corroded use fine (500 grit) paper to clean off or use a brass bush. on really bad sockets I use carb cleaning spiral brushes (soaked with cleaner/lube) to clean out. BUT you don't want to use too large a brush and risk opening up the little socket holes. Last edited by DaveWM; 07-20-2015 at 08:25 AM. |
