Not to bad...not bad at ALL !!
Does it use a tube B+ rect...or diodes ? |
All it needs is a new 6FD7 tube and it should be back up and running again. |
If you have a 6DR7, IIRC it is a sub for the 6FD7. At least, you could try it, until you get the FD. |
Many times the subs listed are only close tube designs and will, only once in a while, cause a new problem. IE: the vertical hold will be critical or the lin or height won't adjust properly. The 6FD7 and the 13DF7 is a Philco designed tube. |
