Old 12-27-2015, 11:47 PM
motorola vt71 ts4j 3rd if issue- it wont light
Tried the tube it is not at fault. I don't think its the ground. Every tube inside lights but this one and there's no signal because of this. Any ideas? Thanks
Old 12-28-2015, 01:08 AM
Did you check for continuity between the tube pin sockets on top of chassis, and the solder tabs below chassis? On a wafer type socket the connection can become broken between the two wafers. Other than that, it could be a real dirty or damaged contact.
Old 12-28-2015, 01:13 AM
It's a series strung set so the only way it's possible is if the filament pins are shorted together. Check for continuity between pins 3 and 4 on the socket.
Old 12-28-2015, 08:02 AM
So if pin 3 & 4 are shorter that is the problem? If you pull the tube everything stays lit so it is making the series still work so must be something odd. Its not a wafer socket but one of those light brown or tan plastic type sockets.
Old 12-28-2015, 09:05 AM
Do you have a schematic for it?
Old 12-28-2015, 02:32 PM
Yes, pins 3 and 4 are the filament. They must be shorted otherwise the other tubes could not be lit up with that tube pulled out.
Old 12-28-2015, 03:04 PM
The schematic shows 5000pf heater bypass caps in the IF strip. Check for a shorted cap. Also, one of the tubes in the same string may have an H-K short.
The tubes are in a series-parallel arrangement.
Old 12-28-2015, 08:10 PM
I have a schematic and will have to check the pins. I think the 5000pf cap is a disc.
Old 12-28-2015, 08:13 PM
I could say if you pull the 2nd if tube some go out butnot after this 3rd if. You have pull a tube after the 3rd if to get the others to go out.
Old 12-28-2015, 09:10 PM
I made a mistake on the disc caps. 250pf.
There has to be a fault on tube socket between pins 3&4. Maybe a solder splash or????.
Old 12-28-2015, 11:43 PM
Sorry, I completely spaced out that it's a series heater string. But that's a weird thing you have going on there.
Old 12-29-2015, 07:10 PM
So the tube that don't light up, did you try another one and did it light up on the tester if you tested it?
Old 12-29-2015, 07:57 PM
I tried another tube and even switched it with the second if and no lighting. When I can will check the pins and socket.
Old 01-10-2016, 10:49 PM
Pin 3 and 4 have no continuity so I checked pin resistance and pin 4 has none. I looked at the wiring and it looks like a resistor was changed. Here's something v4 going to v5 the tube that wont light v4 connects to pin 3 of v5 but v5 goes to v6 from the same pin 3. Shouldn't pin 4 of v5 be going to v6?
Old 01-11-2016, 11:32 PM
Is a ts-18 8 inch Motorola similar so I could compare the wiring?
