Old 07-13-2016, 08:52 PM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
RCA 7-ES-6J Motor Noise
I've been doing minor repairs on my RCA 4 speed suitcase record player, and have noticed a loud buzzing sound from my motor. It's been cleaned and lubricated multiple times, and I replaced the motor mounts for good measure, all of which did nothing to resolve this noise. Does anyone have any suggestions for what might be causing it? Bad bearings, maybe?
https://youtu.be/Sam2PYtG7uI
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
Old 07-13-2016, 09:06 PM
Is the shaft loose in the bearings at all? It should turn freely but have very little slop.
Are the windings tight on the core, if they are loose they could vibrate.
Only other thing I can think of is it's out of balance but that would be unusual.
Old 07-13-2016, 09:09 PM
Dubis7's Avatar
It spins freely. It has a bit of up and down give but nothing I would consider that significant. The windings seem completely held in place.
Old 07-13-2016, 09:10 PM
Dubis7's Avatar
I should also note that, despite all the noise, it runs at the correct speed.
Old 07-13-2016, 11:52 PM
If you stall the motor, does it still buzz?
Old 07-14-2016, 09:22 AM
If you stall the motor and it still buzzes, it could be lamination noise. It also could be a loose shading coil. That problem was most common in AC solenoids.
Old 07-14-2016, 09:45 PM
Dubis7's Avatar
I'll have to check the next time I get into it. That'll hopefully be this weekend.
