Old 09-02-2016, 01:58 PM
reichsrundfu reichsrundfu is offline
If your VCR is not playing through a TBC you will get very different results from sets with different circuits. The sync timing of a VCR varies in ways that broadcasts of the time never did....TVs then were NOT designed to deal with it well, and those that do only do so by dumb luck...Every circuit of the time will handle it somewhat different. Some will be okay some terrible. DVD, and broadcast sources are the only signals where consistency of performance should be present.
Quite agree here. Avoid Videotape at all costs. Stuck with DVD or cable / satellite
Input. Also I kinda suggest you forget about the Blonder Tongue modulator and just go direct hookup s CS you may be dealing with transmission issues with your unit and not with any fault in the tv. Go back to your modulator after your work is complete for the sake on sheer convenience.
Eliminate your variables as much as you can !
George
