Did it make much difference when you ran it with VIR switched 'on'?
As I recall, the vir switch had its own set of controls. So, you could make it look like anything you wanted.
Those vir generators are all over Ebay if you wanted to play with one. Except for the VITS100, they also have a full field test generator with a boatload of test signals. The one I liked was the Tektronix 1910. I've seen them as low as $30. But I think the vits deleter and inserter section could be used in eradicating copyguard thats in the vertical interval.
