Old 03-22-2017, 06:54 AM
Mre12ax7 Mre12ax7 is offline
I think I have found the root cause of the problem.
Video noise on the sync signal. When you turn up the contrast there are various points on the right side of the screen that pull to the right. But when the screen is black, it goes away.
I will be doing some more probing with the scope to find where it is coming from.
Old 03-29-2017, 10:36 AM
The video noise appears on the power supply.
It goes away when the video output tube is removed from circuit and connect to the filament string with clip leads.
