Old 04-01-2017, 08:10 PM
Because of this thread, I chose a TS18 chassis set as my next restoration victim. This is a 7VT2, like shown here:
http://www.tvhistory.tv/1949-Motorola-7VT2.JPG
This looks like a fun project, getting a little tired of doing RCA 8PT70xx sets and needed a change of pace. I verified that r-59 (Sams#) is indeed 22 meg and tests pretty close. Ballast is open, so I am working out a substitute.
Old 04-02-2017, 01:42 PM
Electrostatic yes it's a change from the other .
Old 04-02-2017, 03:30 PM
I have several of these 7 inch sets all hooked up and I seemed to develope these lines up and down on all the sets so I added an amplifier to the antenna and it cured it but just yesterday this one set got the lines back and have no clue what else would do this. All the others are crystal clear and all share the same ant line.
Old 04-02-2017, 05:13 PM
Does it still display the lines if it is the only set turned on?
Old 04-02-2017, 05:34 PM
All the other sets on lines are there and when they are off ,however I took the set to the beginning of the ant string, stronger signal and no lines but this is the set with the annoying hum in the audio so even though I checked the tubes for any heater cathode shorts, showed none but I'm thinking there is a tube in the IF that may have a short causing the hum as well as the lack of the set to operate with the signal that's there since the others work fine.
Old 04-03-2017, 06:51 AM
If all the sets were exhibiting it with a weak signal then it makes me think it is an RF interference issue. Are there any local DTV carriers (beware 'virtual' channels that report a different channel number than their actual carrier) on or adjacent to the channel your using? If you nix the RF amp and hook up a CRT TV from the 80's-00's does it display the same symptoms?
Old 04-03-2017, 09:14 AM
In the last post what I meant was all the other sets are fine no lines but weather the others are on or off the one set has the lines. So the problem is the one set.
Old 04-03-2017, 09:50 AM
I was responding to an older post....I edited to include a quote of what I was replying to.
