Yellowed Zenith dials
Is there a good way to clean these 1969 Zenith dials? I tried it once on a 1971 dial, but the retaining ring got mangled and it would not hold the dial against the plastic anymore.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan |
If it's clear plastic that's yellowed, there's not much you can do. Otherwise... soap and water with a toothbrush?
For bulk cleaning we used ammonia & water. Would cut through
almost anything & keep you awake. 73 Zeno ![]() LFOD ! |
The channel plates of every one of those knobs I've ever seen was that color even the mint condition ones....I'm fairly sure they are meant to be that yellow color.
I have a few and may try some hydrogen peroxide on the outside-facing part only. If that is a surface layer of yellowed material, it may help.
"When resistors increase in value, they're worthless" -Dave G |
IIRC the dial numbers were somewhere between yellow & red.
Non spotlite dials had black numbers on silver. The fine tune knob was CLEAR. Gold was often used also but I think not on this one. If the FT knob is yellowed its prob from UV light & not repairable..... 73 Zeno ![]() LFOD ! |
