Crosley 9-409M1 Schematic
Does anybody know if the Crosley 9-409M1 TV is in the Sams photofact 66 folder 6? I found it listed in an old PF Reporter on archive.org.
I'm looking to find it somewhere, if anybody can confirm that it really is the M1. I have the 94 folder 3 but alot is different. Like a 6AU6 in the IF instead of the 6AG5 that's in the M2 & M3. The TV was worked over by a hack and its hard to follow. Thanks |
Here is the Sams in question... don't see "9-409" :
http://www.earlytelevision.org/pdf/c..._sams_66-6.pdf jr |
Are you sure about the model number? How many video I.F tubes does your set have. The 94-3 schematic shows a circuit variation in the bottom left corner with an extra video I.F tube. Ed |
It's a 419-M1 I didn't see it clearly. Sorry.
You stated earlier in this thread that you have folder 94-3. The information you need should be in your copy, unless it was revised? I cross referenced your chassis number from a 1953 Sams index.
Ed |
Yes but many (a lot) of the schematic values don't agree with what's in the chassis. 6AG5's changed out to 6BA6 & vice-versa, C10 is backwards in the diagram, etc. It's easy to get lost....
![]() So if anybody has an original Crosley manual, maybe that will help. However thanks for trying with the Sams. |
