The lamps are powered off the winding of the transformer with the wire with the arrow on it (each tube heater has the same arrow as does a wire off the dial lamp section of the band switch).
What you need to chase is the open in the AC power wiring. Looking at the schematic it is most likely the main power switch or part of the mode switch/phono power switch wiring...Ohm it all out and the problem should present its self...The transformer is probably fine (though you may as well check it first to avoid wasting time on a set with an open transformer).
