Old 12-31-2019, 11:18 PM
Originally Posted by MadMan View Post
Well I would rule out the PSU first. I'd say it's the more likely failure point. It's hard to be certain, but in general, if the main board had an issue, pushing the power button would elicit SOME reaction from the PSU, like an attempt to turn on, then quickly turning off. A dead PSU would likely have no response at all. Is there like a standby indicator light on the tv?
You could probe the PSU outputs for voltage while pressing the power button, see if anything ever comes out.
The TV does have an LED light but it doesn't light unless you hit the power button, which when you hit the power button the light glows red for about 3 seconds, showing that the TV is trying to power on, but then it just shuts down and the LED goes back off.
I did take a look at the Power Supply board on this TV but didn't see anything obvious that looked like it had failed (no bulging electrolytic caps, no blown fuses, no burnt traces, etc.)
So I'm not sure what's going on with this TV.
