1. Place a 47k resistor between pin 11(cathode) of the CRT and ground. 2. Connect a .05uf, 630v cap from pin 3 and 4(plate) of the 6K6 vertical output to pin 11(cathode) of the CRT. Basically you need a positive going vert deflection pulse at the CRT cathode in order to blank the picture during vertical retrace. |
