#61
Code:
Minolta MV-20S MV-305 MV-605 MV-60S MV-705 MV-120F MV-120S MV-160 MV-500S MV-900S V-700S ![]() ![]() ![]()
Last edited by svhs; 01-04-2021 at 01:37 AM. Reason: SHARP シャープ ビデオカセットレコーダー VC-BS10 |
#62
https://archive.fo/rhp9W
![]() Zenith BASE TAC CONNECTORnovel approach us1ng both a two position RF switch device and the Video/Audio outputs of a baseband CATV decode1· through the VCR' s built in Tuner/Aux. input selector. Some new VCRs even allow the unattended selection of "Tuner" or "Auxiliary" inputs as part of the multi-event programming. With such a VCR, this system allows for all of the desired functions. In operation, however, it is not as simple as it looks. Although there 1s apparently only one two-position RF switch to be concerned with, there are two more twoposition switches in the VCR <TV;VCR switch and Tuner/ Aux. swi t.ch) which must be manipulated. BASE .IA.CPerhaps the ultimate and Jo~est cost VCR-Cable interface is the "Afterburner" approach. This system is so named because the premium pro~ram descrambling IS performed after the subscr1ber receivin!l; equipment's tuner-IP, and demodulation stages. The system depends upon Baseband scrambling techniques, in-band addressing data, and home equipment capable of being adapted. The Zenith BASE-TAG product is a good example of this technique and is compatible with Zen1th' s Z-TAC SSAVI scrambling. Last edited by svhs; 01-13-2021 at 12:18 AM. |
