Looking for a flyback for a RCA CTC 15
I finally found an RCA roundie.
The good: It looks to be a low hour set most all tubes are still originals. The PCB's have little to no heat damage. The cabinet is spotless looks like it is right off the show room floor. The CRT was replaced in 1968 with a RCA Colorama checks almost NOS with a Sencore CR70. Now for the Bad: The flyback is burnt. So I am looking for a replacement flyback part numbers are: RCA 113382 Thordarson Fly 277 Triad D304 Any help in finding one would be appreciated. Thanks Jim |
There were two types of flyback failures in those: a shorted turn which would be evident by a burned stripe around the secondary core and a burn through from the 3A3 cup to the core.
EDIT: Does the 15 have the 3A3 socket??? Back in the old days, we used to carefully scrub down the burned section from the 3A3 cap to the core and put several coats of corona dope on them. We'd do them "in frame" in the house. These would last quite a while, enough time to schedule a flyback replacement or a new TV delivery. I haven't seen one of these in over 40 years but if it has the burn between the 3A3 and core, I'd try removing the flyback and really cleaning it up well. I'd also use the RTV that doesn't have the acetic acid in it. Might be a permanent fix. Nothing to lose to try. John Last edited by JohnCT; 06-06-2021 at 08:51 AM. |
The CTC-15 and earlier all had a wire running 2-3" out of the flyback to the top cap connector of the HV rect. Every RCA color chassis number has a flyback a little different from the others, but the 15 is easy to identify because it didn't use a focus rectifier tube, but instead a a selenium stick focus rect. How have you checked your original to determine that it's bad? There some faults and methods of checking that can easily fool you into thinking the flyback is shot. I've had it happen to me before.
There was an rca tech note that said you seat the 3A3 into its socket with 1/8 th clearence. Then put the top on, and make sure its bolted down tight. Dumb design.
The focus stick I guess wasn’t ready either - they went back to a tube… Didn’t Zenith just use a rectifier with a conventional setup? RCA seemed to make things stupid at times… |
With it out of the set and on the bench the resistance from the core to the connection for the rectifier plate (3A3) measures about 200 Ohms. one side has a burn from the plate wire.
luckily one of the other members has a NOS RCA he is willing to sell. Will post pictures when I get it in and hopefully working. |
Can the CTC-15 fly be converted for tube instead of the solid state focus?
All you would need to do to use a focus tube is add a focus winding on the flyback frame using 10KV insulation rated wire. However every heater load on the flyback increases horizontal output cathode current, reduces HV, and increases opperating temperature of the flyback...All of which are bad things to do. On sets with tube focus I often disconnect the focus tube heater winding, leave the tube in for appearance, and stick a cheap modern 5KV PIV rated diode in. It reduces load, heat, and stress on the flyback and horizontal system, and improves focus in most cases. I can give you a part number for a cheap modern diode if you want.
not to mention. you will be very hard pressed to find a socket for a 2av2 that wont wanna arc out, not too many original ones out there...
i may have one i will look shortly
sorry i do not have that one i have one for a ctc-20 chassis.
That fly is rare, it only works in a CTC20 chassis! 70 degree deflection.
That RCA distributor didn't even have one in stock and that was years ago! That set was a dog anyway. |
It's strange that the 15 is the only RCA color chassis that used it and others copied it. |
I'm guessing RCA went away from the solid state focus rect because the tech wasn't ready yet. Didn't they hold onto the 1V2 or 2AV2 up till the end of the tube era? Oh yeah, the 1X2 in the CTC-2 and 4
The CTC-15 flys (atleast in the clones I own) did have mounting on the phenolic for the focus rect and 66M resistor. On a stock CTC-16 you could probably use the focus rect socket for one or more of the terminals. I'd study the CTC16 and 15 schematics carefully before putting a 15 fly in a 16. IIRC the horizontal stages, their windings, and the windings for the chroma burst and H AFC circuits are different...you might need to extensively modify multiple circuits for such a swap to fully function.
