RCA Selectavision model VKT385 VHS VCR issue
Greetings to every one here at videokarma.org! I'm not very active on here, but I occasionally read & post on here.
I'm having a mechanical problem with a vintage VHS format VCR that I own. I have an old RCA Selectavision VHS VCR, model VKT385, from the mid-1980s, which is just a typical monaural, two-head, front-loading VHS VCR with a 10 button wireless remote control. When I brought it home & hooked it up to my TV, the problem it had was that when I pushed the power button, loaded a videocassette, and pushed the play button, the mechanism attempted to play the tape, but then stopped after a few seconds, but oddly enough, it was able to rewind & fast-forward tapes, but a few times, it didn't wind the magnetic tape all the way back in to the cassette. Three months ago, I took the VCR to an electronics repair shop, and the technician repaired it & got it working again. I'm watching a movie on it right now, and it's working very well. It has excellent video, audio, and recording quality, but sometimes, it still won't transport the magnetic tape back in to the cassette all the way, which mangles the tape when I eject the tape. The repair technician told me that the VCR needed a lot of new internal parts installed, for example, belts, tyres, and idlers, and that it was difficult to work on, with a very complicated mechanical mechanism. He also told me that it's not a true RCA VCR, made in Japan, and RCA never manufactured their own VCRs, and also, that some of its parts are difficult to find today. Does any one know what the problem could be, or if it's repairable? I know that video tapes are no-longer popular, but I'm still a loyal user of VHS & Betamax. I did a search for this particular VCR online, but I can't find very much information about; I found a few pictures of it, but information is scare. On a side note, speaking of RCA Selectavision, I am also a collector & user of capacitance electronic discs, which also uses the same trade name. Thanks for the help! Last edited by B 4204 T3; 07-17-2022 at 04:18 PM. Reason: Too long, so I made it shorter. |
I hope this helps. |
The RCA's of that time period were made by Hitachi.
Two items come to mind giving a tape take up problem. The take up or reel idler could be worn and I have run into some occasions where the cassette tray assembly has a slight bend to it. That places a larger load on the reels. That can affect the supply or take up reel depending on which side the carriage is bent. Obviously your problem is with the take up reel table. Try several tapes because a bad tape can also cause that. Last edited by djski; 07-18-2022 at 06:54 AM. |
Thanks, and new issue
Quick update, and thanks for all the suggestions.
For the last few days, I have been using my RCA Selectavision VCR, and it's still working well, but I looked online for some new parts for it. I found a company which sells parts for VHS format VCRs, and I ordered some new O-rings, a belt kit, and a tyre kit, just to be safe. While playing some prerecorded tapes of Hollywood movies, I discovered a bizarre quirk with the VCR, which I've never experienced with any VCR before. When I loaded the tapes & pushed the play button, the VCR started playing the tapes too slowly. The front display was showing the tapes playing at SLP speed, instead of SP speed. A few minutes later, it played the tapes normally, at the SP speed. Another time, it started playing at SLP, but when I pushed the fast forward button to search, it played at SP again. Does any one know what could be wrong, and has any one else experienced this problem before? I also played the tapes to the very end, and let the VCR rewind automatically, and when it finished rewinding, and I pushed eject, it worked fine, with the tapes completely back in to the cassette. Thanks again! |
Yes, indeed. The VKT385 is a 1984 Hitachi built unit. I worked on many of them in the late 80's and 90's.
1984 was the second year for Hitachi built VCR's as RCA had given Panasonic the full boot a couple years prior in 1982. And, it wouldn't be until 1989 that Thomson went back to Panasonic for several RCA models (VR480, VR620HF, VR625HF and VR700HF) scattered into the (still) mostly Hitachi corral. The first three digits of the FCC ID# on the rear panel of the VCR will give the build away: AHA = Hitachi; ACJ = Panasonic; A3L = Samsung (1987 and later). Brian Last edited by Blast; 07-26-2022 at 08:14 PM. |
But, it can also be that the a/ctl track head of your VCR is out of alignment (or, at least out of alignment with the tape recorded on another unit). However, since you say the speed problem seems to have 'fixed itself' as you were playing it I'm going back to the dirty head scenario and I wouldn't touch a thing related to alignment based on one tape. Brian Last edited by Blast; 07-26-2022 at 08:15 PM. |
Repair question & photographs
Once again, I really appreciate the suggestions. I've been very busy for the last few weeks, so I couldn't respond until right now.
I checked the back of my RCA Selectavision VCR, and one of the labels on the back reads: FCC ID : AHA9670024 RCA CORPORATION MADE IN JAPAN From the identification code, this VCR certainly has Hitachi Ltd. as its OEM. I've read online, and also watched videos, that said RCA's earliest VHS VCRs had Panasonic as its OEM, along with other brands like Curtis Mathes, General Electric, J.C. Penney, Magnavox, Philco, Quasar, and Sylvania. It's interesting to me that back in 1982, when RCA sacked Panasonic as their VCR OEM, and they hired Hitachi to produce their VCRs, General Electric hired Panasonic as their VCR OEM at the same time, after they sacked Hitachi as their original VCR OEM, so it was like a "swap." I wonder what the story on their arrangements was; I would be interested in knowing it. Getting back to my VCR, I've been using it for the last few days, and it's still working well. A few times, the tapes played in SLP for a few seconds at the very beginning of the tape, but then corrected itself & began playing at SP or LP. Last night, I played a homemade tape recorded at SLP, and it played perfectly. Here is my question: If the VCR has an issue with the control track or the heads, then would it be an easy fix, or do I need to buy a service manual to do the job? The only service manual I can find for sale for this VCR is very expensive, so I don't know if I should buy it. Thanks again! |
For the reason that you say, "Last night, I played a homemade tape recorded at SLP, and it played perfectly.", I would respond that a self-recording that shows no rec/pb issues (whereas a recording made on another VCR does) speaks volumes for a possible a/ctl track alignment issue (on the subject VCR). To help rule out any said alignment issues take a paper towel loaded with Windex and thoroughly clean the a/ctl trk head. Up, down, back and forth, over and over... for about 30 seconds. Then, be sure and follow up with your "regular" head cleaner (i.e. clean the crappy Windex off). Now, did that fix the said "tapes played in SLP (that were recorded on another VCR?) for a few seconds" issue? If not, then you should confirm that the a/ctl trk head is properly aligned to a reference standard tape. How are you going to find this reference standard tape? I'm not sure. But, it MIGHT BE this "other" machine (that I believe you may have spoke of) could make them. ??? Maybe that's your tool. ??? You're going to have to decide. It might be that those "prerecorded tapes of Hollywood movies" you mentioned are suitable "reference standards". If you know of another properly aligned Hitachi built VCR (because not every manufacturer had similar ideas of alignment - a topic for yet another discussion - but even ANY other VCR might prove to be a suitable <cough> 'reference standard' VCR) that shines in terms of alignment I would make a tape on it and call it your "reference standard". Would I advise you align your VCR to it? Are there any lawyers present? To summarize, as I said a few paragraphs up, a VCR that plays back its own recordings, better than recordings from other machines, may not have a correctly aligned a/ctl trk head (i.e. aligned to the real world 'reference standard' <cough>). Here's another tip: I wouldn't screw around messing with the alignment of an a/ctl trk head that you didn't know wasn't screwed around with in the first place. Unless you're ready to unscrew it back. Hope any of that helps.
Thanks, explanation, and new strategy
Thank you for the suggestions & quick response.
When I typed my response yesterday, I guess I should have been clearer with what I wrote about my experience with the VCR. The tape that I played a few days ago is a newer Sony T-120 VHS video cassette manufactured some time back in the mid-to-late 2000s, which was recorded at SLP, approximately ten years ago. It was not recorded on this VCR. While I was playing it, I frequently had to adjust the tracking knob. Most of the time, I just keep the tracking knob in the midrange position, which is the spot where it clicks when it gets turned, but when I played the tape in this position, there was a lot of static in the picture, and it was only clear when I moved the tracking knob all the way in either direction. The studio-made movies play fine with the tracking knob in the customary midrange position. I guess my plan for the VCR, at least for now, is to experiment with it by making some test recordings on it at all three tape speeds so I will have references for it, and also try recording on one of my other VCRs, so I can compare the differences they make. I will also clean the audio control track head thoroughly using your suggested method. I don't really know anything about the history of this RCA/Hitachi VCR, since it was a $10.00 Craigslist find that I bought six months ago at someone's house, and when I had it repaired by the TV/stereo dealer near me, the technician must have only done the basic repair procedure; for example, changing the belts, tyres, idlers, and lubrication, but not any advanced, in-depth service. I don't know exactly what he did with the VCR, but it's just my guess. Once again, I can't thank you enough for the advice; I really appreciate it. If you can think of any other suggestions, then I really welcome them. |
If it tracks Hollywood tape releases correctly, but doesn't track tapes from another home unit correctly that suggests your VCR is working fine, and the other home machine that recorded the tape is not aligned correctly.
Test recordings
Here is a quick update on my VCR:
Yesterday, I made some test recordings on a blank tape at all three speeds, with my rabbit ears & loop antenna & digital television converter box connected to it, and it recorded very well, then it played back with no problems at all. I also played it on my newer VCR, and it played just fine as well. My movie tapes are also still playing correctly. What I am planning to do now is order a service manual for it and clean the heads & audio control track. Hopefully, it will still work properly. On a side note, this VCR is very quiet & runs smoothly. It operates much quieter than other VCRs that I've owned in the past. Thanks for the suggestions. |
New problem with this VCR
After using this VCR regularly for the last four months since I had it serviced in the repair shop, a new problem has happened with it.
Yesterday, I taped a TV show on it, after the show ended, when I tried to play the tape back, it wouldn't rewind. I kept pushing the rewind button, and I thought it was working fine, since I could hear the internal mechanism whirring for about five seconds, but it kept stopping, and it wouldn't rewind. I also noticed that the numbers on the counter were not changing, so I knew that something was malfunctioning. Before yesterday, the rewind and fast forward functions worked fine, although slowly, but I couldn't get it to work yesterday for some reason. What is really strange is that the search functions still worked; the tape would rewind and fast forward while I was playing the tape. It works by holding the rewind and fast forward buttons in the entire time while I was searching thru the tape, which is the only way that I was able to rewind the tape & play it back. I also tried playing, rewinding, and fast forwarding a few different video tapes, and the VCR did the same thing on all of the tapes, so I know that the problem is with the VCR and not the tapes. I am confused by what is going on, and why it failed only four months after having the VCR serviced in the electronics repair shop. Does anyone know what could be wrong with it? Any suggestions are really appreciated. Thank you very much! |
Hit the Thrift shops, yard sales. Many times, they can be had for less than you paid for that dog. Maybe even free! |
I'm just now getting caught back on on the thread.
What I was describing in terms of "reference standard" was a complete inability to properly play back a tape regardless of speed or the setting of the tracking control, not just a centering of the tracking control. |
There were some Hitachi designs (not sure if the VKT385 was one, or not) that used, what I'll describe as, a single pin analog system for their function buttons. All the major function buttons (Stop, Start, Rewind, etc.) were wired through different sized resistors so that each button pressed presented a different voltage to a single pin of the microprocessor (uP). For example, pressing STOP might send 5vdc to said pin, pressing PLAY might present 3.2v to the same pin, etc. And, the uP would 'know' to perform the proper function based on the voltage presented at that input pin. So, when the function buttons started getting electrically intermittent over time they might, and would, 'fool' the uP into 'thinking' that a different button had been pressed other than the one the operator was actually pressing because of the additional resistance that had built up in the switches over time. So for that, remove the front panel and spray a little Deoxit D5 into each of the function buttons in order to to clean their contacts. Now, this isn't going to do anything for a slipping idler wheel or some other mechanical problem that's just now surfaced. And, again, I may not be fully understanding the problem. But, if you're having to hold two buttons to perform a function that one button normally performs, this may be the problem. Good luck. |
