CTC 10 " the sullivan"
Purchase a metal cabinet ctc10 2 weeks ago. Came from the original owners estate in Wisconsin. The orig CYP is good and the set seems to work well. Other than typical vertical issues this should be a fun mild restoration project!
Nice to find one with a good tube!
It's a lot easier to find a good CY, than it is to find a good AX!
It's surprising how many of these still basically the work as found. I've got an original blond metal cabinet CTC-10 that besides a bad H AFC selenium diode pack worked as found. I've been thinking about changing the lytics too but I don't run it much.
Nice CTC10
Nice Set! I have the same one with no legs- could you measure the length of one of the legs for me?
Thanks, Kirk
KStanki@aol.com |
Very nice, looks healthy.
Your CTC-10 looks like a very enjoyable project. Just don't make anything worse ! ![]() Phil Nelson Phil's Old Radios https://antiqueradio.org/index.html |
