Also this chip appears to use a 1.2V reference, which there are very few PWM chips that do. What cuts a lot of the market is the fact that they are using this in locked-frequency sync mode which again very few available chips can do. the SG3525 was attractive to do this, but it requires a modified feedback network due to the differences in reference voltage, and the other problem I ran into is its a push-pull design. I tried to sum the output using gates but it did not work well with the glitching and phase compensation issues. I assume they phase-lock the 22011 power supply section for noise reasons, but they also pick off the R/C timing circuit ramp that runs off to the horizontal deflection stage to an extra winding on the yoke. idk if its a pincushion/horizontal parabola circuit or what. So i put it aside for now, I did find a couple different ICs i can tinker with which have single-ended outputs and can phase-lock. I attached the insanity that ensued haha. The picture is hard to see because the forum software is still expecting attachments stuck in 1992. Last edited by mbates14; 09-17-2023 at 08:08 AM. |
Hi to all,
Hi Mbates14, Thanks! for the reply. You have well analyzed the PWR circuitry and your engineering skills are far above mine. Are you sure your CX22011 is dead; i sent one one of my Indextrons to Andy C. and it was a corroded trace under the IC (electrolytic leakage) which caused the PSU malfunction. Andy left the VK forum for personal reasons. He's on ARF (Antique Radio Forum) though and signs "AC". Might still be willing to repair Indextrons. see this thread for instance : https://antiqueradios.com/forums/vie...?f=15&t=427760 Best Regards jhalphen Paris/France |
