Never mind, the 12SN7 was the issue. I'm not used to tubes being bad, trying to look past something so simple, a recovering tube-jockey.
Not done yet, the vertical began to act up. If signal is removed off-channel, the raster collapses to a horizontal line. Vertical hold is good but at end of range, then begins to roll upward. As size is reduced, hold locks in again. All caps have been changed...resistors?
"When resistors increase in value, they're worthless" -Dave G |
