I had a Sharp microwave for 20 years; it finally gave up last month, but I wasn't disappointed when it quit. It gave me excellent service in that time (I bought it new when I moved to my apartment in 1999), which again speaks volumes for how things were built until everything was being made in Japan and elsewhere in the Orient. However, when my Sharp microwave finally quit (it began throwing sparks near the end, and I saw a bit of smoke in the cavity as well the last time I used it), I bought a Black and Decker microwave, which works very well--for now, anyway. I do not expect the new one to last anywhere nearly as long as the old one did, given the cheap and often slipshod way many if not most appliances are built nowadays; however, what can you do?
They don't cook fast enough for many users. The GE over-the-range microwave in my place is 1800 watts and you have to watch how it's used. It could easily overcook or make an item too hot. It's made in Korea and been trouble-free for 18 years. |
Still running one of these. Think mine is a 1979
BTW, I purchased this particular B&D microwave because of the price point (well under $100) and because it is much smaller and lighter (25 pounds) than the one I had. As it is, I needed some help to discard the old Sharp microwave due to its size and weight (due to a bad fall I had several years ago, I am somewhat unsteady on my feet, so I don't trust myself carrying anything that heavy anymore) and to install the new one (even at 25 pounds, it is still heavy enough to throw me off balance all too easily). Your Korean-made GE microwave is doing well after 18 years. My Sharp microwave was in terrible shape when I finally got rid of it; the paint was flaking off the cavity, which may explain why the microwave was throwing sparks shortly before I ordered the new one. The old one would probably still be working today had it not been for that problem, although there were other small things going wrong with it by that time as well, such as the end-of-cycle signal having become so weak as to be inaudible; this signal also alerted the user when any button on the keypad was pressed, and of course I could barely hear that signal either. The sparks I saw when the Sharp microwave was running were an unmistakable sign the machine was very close to the end of its useful life; had I continued to use it in this condition it could well have started a fire, if the microwave did not blow a fuse first. I live in an apartment, so I have to watch these things very carefully, for obvious reasons. I have no idea, however, how or why the paint started falling off the inside of the cavity. I did not in any way, at any time, abuse the microwave ( e. g. slamming dishes, etc. into it), so this is truly a mystery to me. I am at a loss to explain why this even started in the first place.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. Last edited by Jeffhs; 09-22-2021 at 10:06 PM. |
BTW, if your microwave oven is as old as the one I replaced over a month ago, and yours still works, that's great; I hope it continues to give you good service. I don't know what make your microwave is, but if it is a well-known brand such as GE, Tappan, etc. and was made two or three decades or more ago, it's not surprising it still works. In fact, if yours is one of the original Tappan Radarange microwaves, and it still works, I'd hold on to it as long as it does work. If I remember correctly, the Tappan Radarange was one of the first mass-produced microwaves in the U. S. The problem with today's appliances is they are not built with the same quality, precision, etc. as they once were; moreover, most appliances, like almost everything else these days, are made offshore, even though they still bear American brand names. My new microwave, for example, is branded Black & Decker, although I have absolutely no idea who actually manufactured it. My best guess is it was made for B&D by some obscure offshore company no one in this country ever heard of. However, I still have a B&D toaster and a one-cup coffeemaker (same make). The toaster still works well after 21 years, but I replaced the coffeemaker several months ago when the thermostat welded shut. That B&D coffeemaker (my first one, the one in which the thermostat welded) lasted twenty years and was used daily, so I think it gave me excellent service. Ooops! I goofed. The Radarange microwaves were not made by Tappan, but by Amana, IIRC. I don't know if Tappan ever made its own microwave ovens; they may well have gone out of business by about the 1980s or so, if not earlier, before these ovens became as popular as they are today.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. Last edited by Jeffhs; 10-09-2021 at 12:37 PM. |
At home I use a Panasonic microwave, 1200 watts, that I got about 15 years ago.
At the office I use a no-name Asian piece of junk 650 watt one that must be 30 years old and still works well, though it doesn't get as much use as the home one. At the office my students used it a very lot before I retired. But at home I also use a toaster/convection oven even more. Its modern and fairly safe. Its thermostat is also very accurate. |
Is that the one with inverter technology with a stainless steel front?
I found one on the roadside like that. It had a blown up GE-MOV and a burned trace on the control board. After fixing that (and cleaning it up), I sold it on Craigslist for $20. I think Panasonic builds a better microwave than TV's. I sold it to a food truck operator who needed high power and stainless steel. (The state requires stainless steel for food service businesses.) He showed me a binder of licenses and permits and other bull$#!+ documents necessary for the truck.
Sharp R930cs MW
Went by the free public recycling bin yesterday and there was a Sharp MW in there from '07. It was huge and heavy. Looked like a commercial MW. Stainless steel about 900 Watts. Seems to me these large MW's would probably be cost effective to repair. Couldn't lift it out.
You should always pick up a microwave, no matter how bad it looks, just to harvest the magnetron. They're very pricey if you have to buy one.
They're easy to test, even without power. Just check for a short with your DVM between the filament pins and the case.
Well here's a really weird turn of events!
I'm at the Value Village and on the shelf is a fancy looking green handled chrome toaster. It looks like it was barely used. Looks to be the late 60's or even the early 70's and sold by Eatons under the Viking appliance line. Fully CSA certified. (Edited: It's a rebrand of a Proctor-Silex from 1970/1971) This is a toaster I'd use, except for one thing. The plastics are excellent. The cord is likewise in perfect condition. but it doesn't use Mica for the heating element insulation. It uses ASBESTOS! This is going to live in a bag for the meantime. In the future I have an idea to make a clear acrylic enclosure to store it in so it can be on display. Last edited by MIPS; 10-19-2023 at 12:02 AM. |
Asbestos EH? Time to break out the grinder and nose straw.
