Old 12-09-2023, 08:05 PM
Originally Posted by bhegges View Post
The 75 ohms is the setting on the B&K 415 Signal cable, you can select 75 or 300
"fall in the correct place?" maybe not the best way to describe but as I adjust a coil the response curve on the scope moves right or left which has the effect of moving the marker up or down
  • Linked below is a small video of adjusting the 41.25 coil above an below what to me is the peak which I assume is the minimum response
  • https://imgur.com/VRn62J5
I agree on needing to bring it all together, I will follow up with where I am at in a bit.
Is the vertical input of your scope set to DC? it appears it may be set to AC and the whole curve may be shifting up and down, confusing the measurement of the actual vertical position of things.
