#361
I guess using hdmi and use the box to convert it to coax wouldn’t make much difference because it is still channel 3 and subject to rfi
#363
#364
Which one would have a higher channel and does it transmit a signal also using an antenna. I heard of them but not familiar with them.
#365
Connecting channel 3 through cable should work fine, but I understand why you would prefer broadcasting the signal with an antenna to avoid all the wiring.
#366
this has been posted before.
![]() Read this page. https://antiqueradio.org/HomeTVTransmitter.htm the tricky bit will be to find and Agile modulator that they are NOT asking too much for, Phil got his for under $30 but that was years ago before they knew what they could do, now they are not so cheap, but you may find other variants than he got that will work more affordable, AM60-550A AM40-550A AM60-450A and so on as is explained in the page. the one I have is a SINGLE CHANNEL unit, BLONDER TONGUE MICM-b, non programmable, much less power than the Agile modulator, and not of much use as a transmitter w/o a RF power amp, these are factory set at their channels are VHF/UHF ones are getting very hard to find now, but the CATV ones seem to be all over the place.
#367
"The VHF band is further divided into two frequency ranges: VHF low band (Band I) between 54 and 88 MHz, containing channels 2 through 6, and VHF high band (Band III) between 174 and 216 MHz, containing channels 7 through 13" |
#368
Yes it would be nice to get rid of all the wires and yes they all work great on 3 with cable.
#369
