Old 03-17-2024, 08:12 AM
Aperna1985 Aperna1985 is offline
If you can't get anything from the grid of the 6AQ5 video output tube, start taking voltage readings there. Check for open contrast control, peaking coil off of pin 5 the plate, should have 190 volts on it, screen, pin 6, 255 volts. Does the brightness control work?
The brightness and contrast controls work. What's interesting is the black bars spread a little as I adjust contrast. The horizontal hold doesn't do very much. I haven't been deep in the set but I'm wondering if it's a coil. I turned it about 4 complete circles before anything happened. Also there is a little ringing from the yoke.
Also I checked the 255 volts source and tube heater voltages on other tubes but I did not check there. I will check and report back.
