Old 09-10-2024, 10:36 AM
I was able to get the circuit breaker working with some deoxit. I also have a few used but good breakers.
I'm not sure how the rating works for these.
This set pulls about 3 amps, but I see a lot of breakers label "hold 2.1A". What exactly does that mean? Seems like they are undersized?
It is a bit confusing, from what I understand, they are all slow acting, there is the sustained “hold at” rating, and the trip at rating, but it is never clear what the trip rating is, or how long it must be at or over that threshold for it to trip.
I remember dissecting a bad one a long time ago when I was in High School to see how it worked, it has a bimetal contact that's reset by the button, and wrapped around that is a heater wire that has the current running through it.
And, yes, the contacts do burn and fail often.
Old 09-10-2024, 11:08 AM
this is WAY too big, gotta wonder what it's for, but it is the only one i see with both ratings on it, hold and trip.
https://www.ebay.com/itm/30326748117...Bk9SR8D54sq7ZA
Old 09-10-2024, 11:37 AM
I also got one of these to fix the burned focus connector.
https://www.ebay.com/itm/225235664833
Old 09-10-2024, 12:44 PM
Thanks for the links. Just realized I'm being stupid. The breaker is not whole the whole set - it's only for the B+ supply! The filament supply is fused separately. The common 2.1 amp hold type is probably fine.
Old 09-10-2024, 12:58 PM
There is one way to see how much the draw is, including surge, if the breaker is holding, just AC amp measure with peaking across the faulty / removed thermistor, that should give some idea what kind of breaker hold/trip will work.
Old 09-10-2024, 01:34 PM
FOUND ONE!
but it's with 2 lesser ones.
https://www.ebay.com/itm/315321107869
tip point 3.25 amps.
Old 09-10-2024, 01:48 PM
I have the chassis pulled. Can't power anything without putting it all back together. Sames does list it as a 3.1 amp breaker.
Old 09-10-2024, 02:00 PM
that's the only listing for a LITTELFUSE CIRCUIT BREAKER 8153.25, which Sames lists as a replacement I can find.
So I guess it's hold at 3a or so which seems high to me and trip at 3.25 amps.
Get it while you can!
Old 09-11-2024, 03:10 PM
Parts have been ordered. Meanwhile spot checked a bunch of resistors and caps. All are well within spec. Well, except that 0.047 across the AC line. It's very leaky and in the trash.
Old 09-11-2024, 08:34 PM
I measure about 120 ohms cold on the damaged thermistor. That got me thinking a CL-90 might be a good replacement. It can handle 2A and is 120 cold and about 4 ohms hot.
What do you guys think?
Old 09-12-2024, 10:02 AM
It should work. You can always try and see, with the vintage combos sold, they always show the cold rating, but rarely the hot.
Old 09-13-2024, 10:29 AM
Does anyone know the significance of white tipped tubes?
Old 09-13-2024, 10:45 AM
I have seen that a few times before, not sure why it's done. :O
Old 09-14-2024, 09:43 PM
I've seen red and yellow tipped tubes before too...No clue what it means.
Old 09-14-2024, 10:14 PM
John Adams's Avatar
John Adams John Adams is offline
See if they look like original tubes. Manufacturers could mark them to identify them if they were part of a warranty claim. Just a thought.
2 Working Zeniths and one on the bench. Into electronics since the days of Earl "Madman" Muntz..Worked 8 years for a Zenith dealer in NW Arkansas.
