Old 10-14-2024, 11:01 AM
Originally Posted by obsolete man View Post
I found a boost from a leaf antenna that I'm not using. From the combiner, I output to this boost, then this boost goes into the splitter. The antenna that's attached to this splitter works better now. However, I get these ghost bars going from left to right. ...
This is cross-modulation, what you would expect from using an ampifier meant for weak antenna signal levels to amplify a group of higher level signals. You need a cable-system amplifier designed to work at high levels.
