#61
It's all a bit too confusing to me!
#62
Sounds (no pun intended) like it have misaligment... I have seen some intercarrier sets with this behaviour.
So many projects, so little time... |
#63
As I mentioned a while back, the dreaded “Intercarrier Buzz” is horrid with these sets, and much more pronounced with video sourced from cable boxes and digital stuff vs DVD or VHS, which I guess is due to the way they have the video assembled with scrolling text an such, found this out by testing and debugging/ adjusting with a DVD source via rf modulator, getting the sound perfect, only to see it was GARBAGE with the cable box, then I re-adjust for best sound on the cable box, can never get rid of the buzz fully, NOW it's crappy on the DVD source? WTH?
#64
So, it seems that the fussy sets for audio are particulary sensitive to the different sources. I bet some difference in the video response plays havoc here (or even the quality of modulation), besides the video format. A slight HF freq. difference between the sources and it interacts more or less with the intercarrier.
#65
#66
#67
#68
Congratulations!
![]() You now know the horrid smell of replacing an RCA type safety glass! There are no words to describe it!
#69
https://www.youtube.com/watch?v=fp7mg9VbUpw where tape is used. Doug did a roundy for me this way and it worked very well. Also look for posts on this topic on Videokarma. |
#70
Got it. I followed Doug's technique for removing the lens. Hadn't watch the last few episodes.
So just tape is all that's needed. I can handle that
#71
#72
BTW there was almost no odor. I wonder if it is related to the temperature? I got it just hot enough to separate.
#73
Thanks for your advice. |
#74
Nope. I'm not sure if they would have replaced the safety glass when it was rebuilt.
I don't think just the sun will be quite hot enough. I had to use a heat gun on high. |
#75
The RCA we did (21fjp22a) had a very pungent chemical smell to it, that was even noticeable when done outside, the same was noticed with rectangle tubes that had the same type of boding material, however the gummy type in the Zenith bonds did not really stink so much as the RCA.
