Old 01-29-2025, 10:20 AM
Devicemodder's Avatar
Devicemodder Devicemodder is offline
Unhappy Sony EV-C3 cracked gear
My Sony EV-C3 recently started kicking and eating tapes. I discovered a cracked gear (pictured) that is part of the loading chain for the video cassette. What would be the best way to go about repairing this?
Old 01-29-2025, 01:12 PM
Retired Batwings Tech
Honestly look for another machine. The gears were almost always made of "duralon" a type of nylon which doesn't take well to adhesives. I worked in plastics molding for many years with this dreaded resin and have nothing nice to say about it. I know there were some solutions posted on YouTube about how to go about reproducing plastic gears and such and there might be someone who could 3D print this.
Old 01-29-2025, 03:17 PM
WISCOJIM WISCOJIM is offline
With a similar gear on a GE radio, I pulled off the broken gear, clamped the crack tight with a visegrip pliers, gluing it together with Superglue. I then used a tiny round file to bore it out a little so it would fit back over the metal shaft, then glued it to the shaft.
Good luck.
Old 01-29-2025, 08:26 PM
I've tried super gluing cracked Sony VHS deck gears and they always break again within a short time. One thing I have thought of is there are silicone molds that can hold up to low melting point metals like tin. I've thought about making a mold of the glued gear then casting a new one out of the ingots of used solder I've got... haven't gotten to it yet.
Old 01-30-2025, 05:06 AM
redk9258 redk9258 is offline
https://www.youtube.com/watch?v=js5W5Tx9Png
Old 01-30-2025, 01:49 PM
Update: I have fixed the gear. Ended up just measuring and 3D printing a new one. Seems to work alright.
Old 01-30-2025, 03:45 PM
Nice job on the 3D printing!
One way I've fixed them is to cut a thin groove around the gear and then wrap it tightly with a good strong string. Upholstery thread works good. While the string is still under tension, soak the wraps with superglue and leave it till it's set.
Old 01-30-2025, 05:19 PM
for anyone looking for a printable gear, i uploaded it to printables. https://www.printables.com/model/117...video-recorder
Old 01-30-2025, 07:27 PM
Dude seriously you made a 3D printed gear? That totally rocks! Very well done!
Old 01-30-2025, 10:28 PM
I did indeed, and released the files so others in the community with this issue can use it too.
Old 02-01-2025, 12:27 AM
Very nice work! And, thank you for sharing it.
