Old 11-04-2025, 02:16 AM
Videotechie Videotechie is offline
Kolster 6J Frankenstein set
Kolster 6J set needs extensive wiring to save from scrap heap at power supply. The original wiring harness from rf chassis to power supply is still good being cotton braided wire.
The power supply wiring simply fell apart just moving it around to access main multi section filter cap.Nearly 100 yo plastic wiring, probaly some of the first plastic wiring used.
I need to verify transformer is good with meter before rewiring.
Luckily the schematic has color codes for wires as some are faded and or discolored.
Will do work in chunks so not overwhelming.
