I think what I’ll do Kevin is post a list of the caps I’ve replaced and a bigger section of the schematic. I’d like to know for education purposes what’s causing this specifically and how I can diagnose issues like this in the future instead of doing a bulk recap in the power and deflection sections. I’d like to be able to say oh that’s what caused it and not well I changed everything and that took care of it.
If you look in a technical text they use the term Quiescent Current. Different classes of amplifiers idle at different currents. Class A for example is turned on fairly hard at idle, vs the horizontal output is biased closer to cutoff, and acts more so like a switch.
At least now you know where some of your B+ is being lost to. I think once you've replaced the paper caps in the horizontal section your sawtooth will increase in amplitude and the 6BG6 will get it's proper grid leak bias.
I have an idea that might be less painful than the way you're trying to go about this. Identify the circuit location on each of the old caps as you remove them. After you have the TV working with new caps, you can experiment with putting the old ones back, one at a time. Then you can evaluate how they influence the operation. It will be easier to do once you have a working base line. You could even keep a spare chassis on the bench just for experimentation. The more you measure voltages and look at waveforms on your scope the easier it will become to wrap you head around how the circuits interact with leaky or out of tolerance components. |
low ESR. The bumblebee caps were a different story and were all bad. Anyway we’ll see tomorrow if it works, is the same or smokes! |
