#46
Thanks Bob. That appears to be the missing link.
So the transition includes from 1934 thru early 1936 343 lines with a 4 MHz channel and 2.25MHz carrier spacing. For the July 1936 343 line first public demonstration, RCA engineers moved to the 6 MHz channel where it was first used with double sideband video and a 3.25MHz carrier spacing. The question remains when the 4.5MHz carrier spacings were adopted. The RCA paper said the first time it was applied to the transmitter was March 1939 which agrees with another paper I read indicating VSB was first implemented just prior to the NY World's Fair in April 1939. Logically VSB was probably first tested on a 3.25MHz carrier spacing channel for direct comparison with 3.25MHz carrier spacing full double sideband. VSB 3.25MHz spacing would not entirely fill the 6MHz channel and so this would suggest by March 1939 4.5MHz carrier spacing was introduced. |
#47
NO, as all the actual dated original documents that have been presented here have shown, the 343 line field test was NEVER at 3.25MHz carrier spacing. The RF Alignment manual I copied showed they were aligning the 343 line RR-359 sets to 2.25MHz in November of 1936. I fail to understand your instance to the contrary without ever providing a single piece of original documentation of support. Last edited by tubesrule; 12-27-2025 at 07:08 AM. |
#48
So the impeding move to 441 line was pending, I have not found a date for it's first public demonstration but i suspect it must have been late 1936 or early 1937. So for the record, I fully agree with your statement and appreciate your dilligent clarification. |
#49
I'm surprised they didn't use RCA acorn tubes/valves in the
tuner,these were developed by RCA and available by the mid 1930's.Performance would have been way better.954 955 956 series https://en.wikipedia.org/wiki/955_acorn_triode |
#51
I decided to partially reassemble the set while I focus on the power unit chassis down in the workshop.
![]() ![]() I need to remove a bunch of screws and rotate that screen mask 90 degress. ![]() ![]() Also picked up an RCA highball glass from the 1939 New York world's fair to celebrate when I get it working. ![]() A heavy duty turntable makes it much easier to manipulate the very heavy PUI chassis on the workbench. ![]()
#53
A real eye towards serviceability the way that chassis is mounted. Now, remember, you're only allowed to use your RCA equipment when testing this. Have to keep it real.
That's a great decal. I wonder if anybody has fashioned a reproduction yet?
Bryan |
#54
I have water slides of the "RCA Television" decals I made on my Alps printer using gold foil. I'll send Bob some.
(artifacts are not in original) Last edited by tubesrule; 12-30-2025 at 10:36 AM. |
#55
Thank you. I do plan on having the cabinet repaired and refinished.
I started on the PU by checking the resistance of all the transformers and filter chokes. All appear to be OK, except for the replacement HV transformer. The HV secondary is open. Out it goes. I wasn't happy with the way it was crammed in there anyway. ![]() I also removed the added 2.5 volt filament transformer. ![]() You can see the scars where openings were enlarged for the TRK transformer. ![]() I'll be replacing them with two Triad filament and a neon sign transformer. ![]() ![]() I'd been tipped off that an RCA radio from the 30s might have a suitable shell. That trigger a memory that I had parted out a rough 1930 Radiola 80 years ago. I went hunting in the garage and sure enough I still had the power chassis. Bingo! The largest box is exactly the right size! The three new transformers should fit nicely inside and I can restore the wiring to the original configuration. It will also hide the cuts made in the chassis. ![]() I need to bake out the contents and strip the brown paint. A few taps and it will drop into place. ![]() While I wait for new transformers to arrive, I can start on restuffing this box capacitor.
#56
Mouse chews there? Damn rodents!
#57
Looks like it. That's about as far as they got though thank goodness. No rodent urine corrosion to deal with.
Moving on to the bleeder resistor board. It's warper and cracked. Seems they added a ceramic standoff during the "B" upgrade which put stress on the board. You can see the two holes where it used to have a metal support like on the other side I'll fabricate replica dogbones using this technique and repair/replace the phenolic board ![]() ![]()
#58
I guess you want to be as authentic as possible, but I wonder if, since you're going to use modern resistors in handmade dogbone shells anyway, why not keep the original resistors in place on the phenolic board but take them out of circuit while mounting the new resistors in circuit hidden on the back of the board? The original resistors could be kept for display on the front while modern resistors do the actual work on the back. Would save the time and effort of making new/old looking resistors and you'd keep the originals.
#59
#60
Bob, the story about the “001073” stamped on the chassis is one of those absolutely charming coincidences that always make me smile.
And Daryl, I could be wrong but although Ray Kell was surely often the smartest guy in the room, I don’t believe he was a PhD. |
