Old 04-06-2026, 11:44 PM
vol.2's Avatar
vol.2 vol.2 is offline
Originally Posted by TinCanAlley View Post
then if need be, I can use the 695 as a replacement for those other transistors?
If you show me a circuit (the schematic) with a transistor, and you give me both the original transistor and the one your are thinking about replacing it with (and their datasheets), then I can probably tell you with some confidence if it's going to work.
That's about the extent of my knowledge with this stuff; one at a time. I can't sign off on blanket replacements between transistors regardless of the use case. I'm not that good at it.
