Your comment about many old 78-rpm changers being replaced with 4-speed units in old radio-phono combos when LP records came into vogue got me to thinking. How many people ditched their 4-speed turntables when CD players were introduced? Most bookshelf stereo systems, my Aiwa CX-NA888 (made in 1999) among them, do not even have a turntable as standard equipment, although these turntables are (or were) available as options. However, the only turntable which will work with these systems is the original Aiwa turntable, which has a preamplifier stage. Try to use a standard turntable (no preamp) with this system and all you'll likely get is very weak or no sound. Speaking of replacing 78-rpm changers with newer 4-speed units: If your treasured old radio-phono combo system has a preamplifier ahead of the output stage (these were very common in old Philco rp's that had the Beam-O-Light changer, for example; the output of the cartridge in these changers was quite low compared to modern ones), be sure to remove the preamp tubes, or otherwise disable the preamplifier stage(s), when you install the modern changer. This is to prevent the output stage from being overdriven by the high output of the modern cartridge (most antique r/p's had phonographs with very low output cartridges, hence the need for a preamp). The Victor TT in that Philco you mention may have been a 4-speed LP changer, being used to replace the console's old 78-rpm turntable. Once LPs burst on the scene the 78's days (for the records themselves and single-speed turntables/changers) were numbered; eventually, the 78s...well, they didn't actually die (they show up on ebay every now and again), but, as the saying goes about old soldiers, they just faded away.
