Admiral 20X11 restoration
I figure while I have my 20X12 up on the bench I might as well tackle this set too. It's the black set on the left.
![]() It appears to be a very early revision of the 20X1 chassis. It also has quite a few original Admiral branded tubes including the CRT. ![]() When I pulled the knobs off, a few small washers came falling out. I was puzzled for a while - where did they come from ? Finally, it occurred to me that they are spacers between the inner and outer knobs. Without them, the knobs have a tendency to track when rotating one or the other. I have a few Admirals sets with these same knobs, but never found washers before. I suspect they all were lost over the years and never replaced. ![]() It's had some work done over the years. I'd say about half the original caps have been replaced. The two multi-section electrolytics are original though.
