Old 07-29-2025, 10:45 PM
More bad luck!
Was trying to adjust the Width and lin a bit more today and suddenly lost brightness and vertical height, it would sometimes come back, but quickly fade, HV was fine, but something was clearly wrong, did not take long to find that one of the resistors that I had left alone ( candohm ) had failed, R215, (260 ohms 11w), so, ordered now is a RH025261R0FE02 261 ohm 25w, the closest I can find. will be here thurs, since I missed the window for them to ship it today.
Old 07-30-2025, 10:47 AM
Yop, Mouser just shipped it about an hour ago.
Tiny little thing for a 25w resistor, looks like this.
https://i.ebayimg.com/images/g/pWYAA...lE/s-l960.webp
Much smaller than the failed 11w one that I opened to look inside.
It had not burned open or anything, but failed due to corrosion where the metal clamps to the nichrome resistor wire inside, I must have disturbed it too much bumping the HV case where it's mounted,when trying to adjust the horizontal linearity that is right near it.
Old 07-30-2025, 04:22 PM
Well you better get an insurance policy when you’re done with that set by the time you are done with it you can call it NOS new old stock.
Old 07-30-2025, 09:23 PM
I knew it was a bit of a risk not to replace those resistors, but is did not expect it to fail so soon, after they checked OK when I first got it, I have left them alone in half the sets I have so far and they have been fine for years, it's just this one that bit me!
Old 08-01-2025, 06:05 AM
Resistor came yesterday, and all is working again!
back to where I was before, trying to get the linearity as good as i can, for now.
http://suzaku.live-evil.org/0801250534.jpg
fail point on the old candohm.
Old 08-04-2025, 11:43 AM
As I mentioned, I am unable to get the stretch to go away on the left side completely, I can make it a bit smaller, but not go away, I suspect it's due to the one 56pf cap in the yoke on one of the 2 wingdings for the horizontal, which I will leave for now as I don't want to pull it all apart again right now.
I had one other brief fail, the contrast pot, 10k, completely open, no biggy, but of course, the new one has a shaft that does not match, so fitting the OEM knob will be a pain.
And with all the runtime so far, the 2nd FBT has not lost a single drop of wax, and is running cool!
Old 08-05-2025, 08:42 AM
Like I said earlier - the left side is controlled by the damper circuit. The 56pF cap in the yoke is to suppress ringing.
Swap out the damper tube or tinker with the values in the damper circuit.
Old 08-05-2025, 09:33 AM
Sorry, with all the downtime Weirdness, I missed that post of yours.
Old 08-05-2025, 10:25 AM
One thing that has been bugging me about the damper area, is how R199 (10K) is hooked up, every schematic shows it connected to pin 3 (far side) of the horz linearity coil, but when I got this, it was hooked to pin 1, which is the damper cathode side, and I put it there when I replaced the resistor, so was this a factory update? Error by someone who worked on it in the past? Could this be causing the stretch issue?
Old 08-06-2025, 10:44 PM
https://youtu.be/QgqQGi0XazA I have got it pretty much as good as I can get it.
Old 08-07-2025, 07:46 AM
kvflyer kvflyer is offline
Looks pretty good. Certainly, a labour of love.
Old 08-08-2025, 04:41 PM
Yup it looks great 👍
Old 08-15-2025, 01:58 AM
Dude111 Dude111 is offline
Analogue is Awesome
Yes looks very nice!!
Old 08-28-2025, 07:36 AM
Is this site really working again?
Width reduced and horizontal linearity tweaked, but still not perfect, better than it was, prob never will be. As someone said on FB,
never expect perfect linearity on such an old set.
Have to adjust height a bit.
https://antiqueradios.com/forums/dow...?id=525744&t=1
Old 09-11-2025, 02:29 AM
Come on FIX THIS SITE ALREADY!!
