Old 04-01-2026, 04:08 PM
kf4rca kf4rca is offline
Volvo Meltdown at McDonalds
I don't understand how these things happen. Seems to me this shouldn't happen with a modern late model car.
Old 04-02-2026, 07:43 AM
Lookupaplate.com indicates it's a 2011 model. The township where this occurred (Doraville GA) does not have a fire department.
Old 04-02-2026, 09:24 AM
DavGoodlin's Avatar
Motorola Minion
I hope they weren't injured. No FD sounds like a now-desolate area, de-investment in rural USA. Some ghost towns in PA still have a FD.
A friend of mine had his AT oil overheat and car-becue his 3 YO truck, trailer and boat in rural western PA, descending a long grade.
He and buds got out, GM wrote a check (ins?), we cheered. The "yinzer" later went shopping for a new Ram, despite our cautions.
-Dave G
Old 04-02-2026, 10:35 AM
Looks like the firewall did its job.
Some cars use wire insulation that rodents like to eat, then the cars either catch fire or become inoperable.
If your injector seals leak or oil leaks onto the exhaust that can cause a fire too.
Regardless of the age of your car having an extinguisher isn't a bad idea.... Except for EVs/hybrids... Lithium batteries provide their own oxygen source so they can't really be extinguished...drive a burning EV into a lake and it'll keep burning underwater!
Old Yesterday, 10:05 PM
Excessive Oil Consumption on newer cars, and longer oil change intervals, and the
all too common poor quality on newer cars is most likely what helped with this
fire.... From G
The 2011 Volvo XC90, particularly with the 3.2L engine, is known for high oil
consumption due to faulty piston rings, which can cause severe engine damage
or, in rare cases, spark combustion issues. Consumed oil fouls spark plugs and
damages catalytic converters. Immediate repairs are recommended to prevent
engine failure.
Oil Consumption and Fire Risks (2011 XC90)
Engine Issues: 2011–2014 models with the 3.2L engine (and some T6 engines) are
commonly associated with excessive oil burning, often blamed on faulty piston ring
designs that fail to drain oil properly, allowing it to burn in the combustion chamber.
Safety/Fire Risk: While often causing performance loss, extreme oil consumption
and accumulation in the combustion chamber can lead to carbon buildup,
overheating, and potential fire risks.
Both G and YT are full of engines exploding from people going 10K and even 20K
miles between oil changes.
Ever seen the "just rolled in" channel on YT? Unbelievable....
