Old 01-31-2007, 10:41 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
hey Don,
Have you put the tube on a tester yet to see what its emission is?
as far as high voltage goes you should be just fine with 13k B&w does not need to have exact high voltage to maintain luminance. 11k you should still see a good pic. Does it bloom when you crank the brightness? if so, then it is an HV problem, if not then it is a CRT problem
Look at your service data and see what the voltages are supposed to be at the CRT socket. if any are off by more than 10-15% good chances are you have some chassis work to do.
Jordan
