Originally Posted by old_tv_nut
The 75% bars are not 75% saturated, they are 100% saturated, but 75% amplitude. However, they are usually set next to a 100% white bar, which makes all of them look darker by comparison. When this pattern is used, it happens that the yellow bar chroma peaks equal the amplitude of the 100% white bar, so it is safe from overmodulation.
Thank you very much for this correction!
The picture posted by Pete is actually quite good, just the white balance and exposure of the still camera is off. I have attached an adjusted copy, which should be much closer to the visual effect in person.
This picture with adjusted white balance does reveal what the the visual effect in person on a CT100 might be.
Here is a link to color bars on a 15GP22 which looks similar to your adjusted copy:
http://bs.cyty.com/menschen/e-etzold...5inBetrieb.jpg
- Eckhard
