Check to see if the 6BK4 and CRT are lit, they are on a different filament circuit than the other tubes.
A lot of the time, the power switch goes bad, especially if it is a push-pull type. Put the ohmmeter across the power cord plug prongs (unplugged from outlet) and see if you get continuity (a few ohms) when the power switch is turned on. |
