Old 11-17-2008, 06:00 PM
Damper tubes were a common failure in Zenith sets. A quick check for a damper tube is to slightly remove it from its' socket while the set is on and if the pins arc to the socket, it is conducting and should work in the circuit. They can also arc internally when bumped and should be replaced if they show these signs.
julian
