Philco console help!
My wife and I bought a very nice 1946 philco console off craigslist for $75. It works, but I can't get any stations, only static, which changes pitch and intensity as you go down the dial. Has a large built in antenna that is movable, and it hooks to terminals 1 and 2, and terminal 3 has nothing hooked to that one. How do I get this to tune some stations?
DON"T BELIEVE EVERYTHING YOU THINK! |
Well, probably its going to need a rebuild in order to operate properly. Many of the capacitors will have dried up and won't be working properly anymore. Most of the time an old radio will come back to life with new caps and little else, but sometimes you'll find something else wrong. Caps are a good place to start though.
http://www.antiqueradio.org/recap.htm
Random bits of stuff in the collection: Yamaha YP-D4 turntable with B&O MMC 10E cart Allied 495 receiver 2 Magnavox amps, AMP150 and an AMP178, currently under the knife. Onkyo TX-4500 Onkyo Radian III speakers |
Ah shucks! I wanted to listen to some vintage am so badly. My philco model 70 works very well, but scares me until I have it checked out. Guess I better have a look at this console too!
Playing a radio of this vintage without changing the electrolytic caps and paper caps is asking for trouble! Even on a radio that plays, all of a sudden one of the caps can short and blow and depending on where it is in the circuit, it can take out the rectifier tube and, heaven forbid, the power transformer! Time to put its feet in the air and give it some transplants. Another thing to do: clean the tube pins and sockets. Sometimes dirty contacts keep a set from working. Pull tube, spray pins with CRC Electronics Cleaner (auto parts store) and plug in and out of the socket several times. Put your computer onto Live 365 and pick out a big band station while you're working!
![]() Reece
Awesome! I'm on it. These old radios are sooo cool!
But be warned they are extermely addictive, soon you will have enough consoles to build a small bungalow
I have 3 highboy's from the 30's, a 41 Emerson console, a philco low boy, an airline console, 3 phonographs, a philco tv and numerous table tops, there is even a jukebox in the mix. all in a one bedroom apartment, so be warned
Jason- |
They are addictive. I keep thinking about buying this 1947 Motorola console on Craigslist. I can't think of a spot to put it, but darn it I want it.
I have some Philco service bulletins on my web page - take a look. http://www.audiophool.cjb.net/Philco.html
I have 70 myself, waiting for restoration eventually - needs a speaker and cabinet work (sound familiar?). |
You'll soon find out that compressed air cost way to much and you'll use one can per radio. I bought a cheap shopvac with the blower port and use a stiff paint brush. I also notice the electrical cleaner bought at the autoparts store will work great to clean sockets and controls, never use w-40.
Jason- |
There are ways around expensive exact replacement speakers. Old ones can be reconed (also somewhat expensive) or new or used ones of the same diameter can be substituted. If the old speaker had a field coil those can be subsituted for, too, with chokes and resistors. Unless the radio is a rare jewel, subbing a speaker may not be a sin. Purists may now come back down from the ceiling!
![]() Reece
