Or, I could have a solder splash that I missed. The errors in the schematic don't surprise me. While repairing my Sony STR-V55 receiver I discovered four electrolytics that were not only shown backwards on the schematic, they were installed that way at the factory. Fortunately these only see 10mv since they bypass the emitter resistors. John |
I wasn't aware that electrolytic caps contained PBCs, some oil filled caps, yes. I don't think the standard electrolytic one would find in an old tv or radio would contain any PBCs. Correct me if I am wrong. |
Only oil filled ones had PCBs to any noteable extent, and even there, it's not much.
Big deal, wipe it p and toss the mess away, and you're good to go. The PCB danger's overstated bigtime they were used in everything years ago... |
Exactly. |
I don't think it's necessary to do a slow forming of NEW 'lytics. When I worked on new circuits in the lab, we just turned them on when the tech finished constructing them. However, in an old set even with new 'lytics, I do feel safer starting, say, 10% low rather than 10% high! Hand on switch while watching for arcs or smoke the first time!
I use a variac to bring up re-capped items for the first time. This, as mentioned above, helps isolate inadvertant shorts, etc.
Luckily, the variacs that I have are coupled with an isolation transformer and have both current and voltage meters. This makes it safer to bring up hot chassis sets and makes it easier to spot trouble. These particular variac systems are identical Heathkits. I built one myself years ago and purchased the other already assembled. |
I kept increasing the variac to 120VAC when the lights went out. The watt-miser has surge protection built in. 120 on the dial of this new variac turns out to be 140VAC at the output. It has a built in voltmeter and when it reads 120VAC the output is actually 130VAC. The surge protector just did it's job and tripped a circuit breaker. The watt-miser is o.k. I was hoping to monitor power with it as I brought things up. Guess I'll go back to the trusty ammeter. John |
